WTF: 4 month old LED bulb flickering
desura
4,627
129
101
Had it in the bathroom. It was a cheap one, but still, it was LED and I expected it to last 20 years.
Flickers. This is worse than incandescents.
13,979
Probably a crappy AC-DC converter. May have gotten moist from being in that environment. If you trash it, at least keep the LED modules, they're probably still good.
I'm a monster and put 4 CFCLs in my bathroom, so far so good...
PottedMeat
12,363
475
theres a lot of garbage out there. the leds themselves may be ok but add in bad passives, poor soldering, stupid thermal design and you get shitty bulbs.
Carson Dyle
8,173
524
I've had a couple of cheap LED bulbs do the same thing after a bit of time. I think they were both Target branded bulbs.
DCal430
6,020
9
I have learned when it comes to LED cheap bulbs are cheap for a reason. They are often very low quality. They are often poor efficiency and have a very short life.
BarkingGhostar
8,410
1,617
To assume a manufacturer builds for duration would be a faulty assumption. But, the first LED bulb I bought is 4.5 years in running constantly and coming up on 40,000 hours.
Now, I have a couple of LED bulbs that have been continuously operating in outside sconces since November 2014 (~20K hours) without a flicker and those are house brand from Lowes. Not a single flicker and have survived through winter cold and summer heat and humidity.
pontifex
43,804
46
I got some cheap ones from costco. 1 completely went out and another started to flicker. not sure how long they have been in, less than a year I would say, though.
these are in a ceiling fan in my living room.
