ThanksIf you want to spend the cash for a Red Pro, then, yeah, it will work fine for that.
Thanks
Believe it or not, its the cheapest 6T drive currently avail. if I want 5 years warrenty![]()
For whatever strange reason they got, they are basically using 6TB+ drives in enclosures for vastly cheaper than the internals.
Not too long ago, you could get a 8TB WD easystore for $160, and shuck it.
That is pretty depressing if you ask me.
Internals should always be cheaper, they lack the PSU, case, circuit board for the bridge chip, USB cable, packaging, documentation.
Everybody is on somebody's *-list.For some reason found an 8T for marginally more, gonna go with a Seagate barracuda pro instead, still 5 years.
Unless seagate is on the * - list?
