WRT54GS and HyperWRT firmware/signal transmission question
Lord Athlon
111
Ok so i have a WRT54GS V 2.0 and today i decided to try the HyperWRT firmware since i heard good things about it.First you need to know that my access point is located upstairs in my house and my other PC downstairs and i always had some weak signal issues since it has to go through a bunch of walls and other stuff (and no i cannot really place it elsewhere for now).The principal reason i wanted to use the HyperWRT firmware is because of the signal boost option which leads me to my question :
I cranked it up all to 100 % and the reception on my other PC is now MUCH better than it was at the default 50%.It connect almost instantly and everything is faster.Now , it's all fine and dandy but what i want to know is if it's safe to keep the transmission setting at 100 % ? I have heard that the router may overheat and be damaged because of it , is this true ? I have been running like this for 4 hours now and there are no signed of overheating or anything of the sort.And , would getting this be a better solution (kind of expensive though , actually more than the router itself lol) :
»www.linksys.com/servlet/Satellit···19675B04
Thanks in advance for any help or clarification
nweaver
6,813
anytime you add more power to something, you also add heat. Can the default heatsink/case handle the heat? I don't know, there are other variables, such as amount of additional heat, ambient temps, airflow, etc.
JackMDS
29,539
418
Please note that Boosting the Signal in the way it is done by firmware, Boosts the signal and the noise together and thus at a certain Amplification point it actually make the connection worse rather then better. http://www.ezlan.net/wbars.html
The typical sweet point of the Linksys is about 60-70mW.
I think that in HyperWRT it means changing the setting from 50% to 67%. (HyperWRT indicates the mW as well).
