WRT54G wireless bridge
gurujeff03
9
I got my WRT54G working as a wireless bridge using DD-WRT V23 (thank you)
However I can not connect to it via wireless. The only way I was able to accomplish this is using router C. I was able to connect to router A via wireless but that defeats the point of why I connected the bridge.
Router A-------Router B WRT54G (wireless bridge)
WRT54G<====>Router C Dlink DI624 (wired connection)
Is there a way to connect to the WRT54G via wireless. I have DD-WRT set up in "client mode" wireless mode with the network "mixed". The operating mode is in "gateway"
Can you connect to Router B via wireless???
JackMDS
29,563
432
1. It might be nice if you would disclose what is Router A Brand and Model.;)
If A is not Linksys 54G it might not be able to connect.:shocked:
:sun:
JknowWhat
206
IIRC, wireless clients cannot connect to a bridge. However, (all?) the wired connections should work on that bridge. It sounds like you should either a) set up the router(B) as an access point if possible or b) plug in a wireless access point into the bridge so that you can connect wireless clients that will lead back to router(A)
Hope I'm right and I hope this helps.
skyking
22,898
6,069
to get wireless access out at the end of your chain, you'll need to use WDS.
In that setup, each router serves as an access point for the local wireless and wired clients, as well as a bridge back to the WAN connection.
