- Aug 22, 2008
- 6
- 0
- 0
Hi,
I'm looking for some help with my problem. I cannot connect to the Internet using my Linksys WRT54G (v. 6) router. I can connect with just the modem provided by my ISP (Fibernet), but when I follow the instructions in the Setup Wizard for my router, I cannot connect. The problem seems to be at the point where it prompts for a password input. I have tried resetting the router and using 'admin' as the password, but this doesn't work. I have also tried leaving the field blank and this doesn't work. My router worked fine with my old ISP (Comcast), but now it isn't. Could the problem have something to do with my router not being properly configured for a static IP address? I've tried resetting the router the normal way. Is there another way to do so?
I've power cycled the router and modem a number of times, and searched through the forums here but I couldn't find an adequate solution. Can someone help me please? Thank you.
Edit: Sorry, I accidentally double posted... (what a dumb mistake!)
