Originally posted by: Marlin1975
No one quart will not do any "damage". Heck you can run all 10w40 if you like. You migth lose a little gas milage but that is all.
Thanks. I did seem to notice that. It felt a little... "sticky" and the gas light was on before we got it home.
There is no way you would have felt the difference between 10w40 and 5w30.
I was going up mountains with 65MPH speed limit and stayed under 50 because it felt "gummed up." In a short distance I went from having over a quarter of a tank to having, well, fumes. FWIW, the oil level was still very low.
You have maybe done some damage since the oil level with +2 quarts is still really low. The oil cools and lubricates the engine.
From the other thread the difference between a 100% 0W30 and 100% 0W40 oil is about 2% fuel economy, which you won't notice on a short run (about 0.5 mpg on a 25 mpg combined cycle). The loss of power would be in the same low single digit percentages...
and your 10W40 was diluted with 5W30 too...
She BOUGHT two quarts. We didn't ADD two quarts. In addition to this, there was regular Valvolene at the last oil change, a quart of GTX Full Synthetic added when we had to add some last time (all we had available), and the quart of 10W-40 Penzoil. It may have been the effect of combining three kinds of oil brands/types. You aren't really supposed to mix your own "synthetic blends," especially across brands, so that may have a bit to do with it!
You said you bought a quart of 5W30 and 10W40 and accidentally added the 10W40, it was reasonable to think you added the other quart if it was "really" low.
Anyway, my sister and I took it out last night to take my niece to work. When stopped in the parking lot with the engine running, though still in Drive, it sounded like it was skipping/slipping/missing every few seconds or so, but this went away at-speed. After dropping her off at work, it was doing it there too but continued doing it while accelerating. Crap. I hope this isn't related to the three kinds of mixed oil or, rather, I hope it is and can be fixed with an oil change.
That could be related to too little oil.
Without the film of oil the there will be more wear, the pistons will slap and the clearance crank and bearing will increase, resulting in a noise "like a tractor". With no oil you may have as little as 2 miles before your engine seizes (depending on how you drive it).
Edit: quote fixed
Go for 5W-20 since that is what is recommended. Synthetic is probably overkill, and blends aren't much better than normal dino oil. The recommendation for blends is to buy regular and synth. and pour them in yourself, you will end up with a higher quantity of synthetic for the same price.
