Wrong "home" for weather widget in OS X notification bar
EvilYoda
21,198
9
So I updated to Mavericks when I was on the road and now the "home" city is the one from when I was on the road. I've added my actual home city but still don't have the option of deleting the original. Any ideas on how to change this?
Childs
11,313
7
Don't you just click on "i", then click the red minus next to the city you want to remove?
EvilYoda
21,198
9
You would think so, but there isn't a red minus button next to the wrong city. I can delete the home city that I added or add another one, but I can't delete the first city.
Childs
11,313
7
heh...interesting. You must have enabled location services when you set up the machine. You can somewhat configure it by going into System Preferences -> Security & Privacy -> Privacy, and unchecking Weather. This at least allows me to remove the only city that cannot be removed in the widget, which actually has a location icon next to it. I'm looking at this on a desktop at work so I don't know if this will specifically address your issue, but it might point you in the right direction.
One thing thats strange is that your location didn't update when you connected to the internet in your home city. Maybe this data isn't updated, and toggling it on and off will force an update with the proper city. Maybe disabling the widget and re-enabling it would force an update as well. At the very least you can disable location services for the widget and manually enter your city.
EvilYoda
21,198
9
Ah, yeah, that makes sense...still getting used to Mavericks. I tried deleting and adding the widget but the original location was still in there. Thanks.
