- Jul 11, 2001
- 41,371
- 10,483
- 136
I went to back up the HD in one of my Lenovo T60 laptops a week ago with Acronis True Image WD edition and it reported that it couldn't complete the backup because of bad sectors. I ran CHKDSK and it reported several bad sectors. It ran to completion and when I tried to boot the machine I could get only this:
A disk read error occurred
Press Ctrl+Alt+Del to restart
I went into the BIOS and ran the HD diagnostic utility in there and it said this:
Result Error code 0000: Read verification failed
<<< An error was found. Call for service >>>
I figured the drive was dead or dieing. Today I put the drive in a caddy and attached to my other T60 laptop and Windows 7 said the drive was unformatted and offered to format it. I figured why not? I did a full format. I then ran WD Data Lifeguard Diagnostics and it passed the Quick Test and at the end of the Extended Test it said that there were bad sectors and it offered to fix them and I said OK. It then passed the next Extended Test. I downloaded and ran Crystaldiskinfo on the drive and it registered "CAUTION" for it.
Well, I'm thinking I can put it back in the machine and install XP from scratch from recovery disks. Here's my question: Is it a good idea to write zeros to the drive first? Will this make it more reliable for a longer period of time? I figure to back up immediately after I have the machine set up in case the drive does die sometime soon. I realize that XP will not be supported now, but I won't be doing any online activity with the machine and I think it's safe from intrusions once it gets current updates.
This HD is a Western Digital 320GB Scorpio Blue SATAII 5400RPM 2.5IN 8MB Bulk/OEM Hard Drive WD3200BEVT, manufactured in May 2011, so it may well be in warranty, I haven't checked that.
Thanks for any insight here.
