Write protected USB Flash drive
Skurge
So I gave my USB flash drive to a friend, unsurprisingly he returned it with a virus. Now I can't format the drive as it keeps saying its write protected.
Someone said I should use Active killdisk. Well it was taking 3hrs to format the drive so I canceled. Now the drive doesn't have a drive letter and I can't assign it one in disk manager.
Using Win7 64bit.
What do I do now?
You should be able to fix it using disk management.
Click start, type diskpart in the search bar & hit enter.
Try these commands:
list disk (make note of your drive number)
select disk (your drive number)
clean all
Then drive management should work for you.
Viper GTS
Try these commands:
clean
Viper GTS
Still tells me "the media is write protected"
Try using vconsole's USB flash drive tester. It does raw writes to the flash drive, bypassing the filesystem. If you do the full test, it will wipe out everything on the flash drive. See if that works. vconsole.com
