I have a TT Tsunami with the 90mm side fan. I put a dust filter on that a while back to (what I thought) reduce my temps. Well, today I took it out of of curiousity, and I noticed that my max temps went from around 57 C or so (very high) to around 52 C (not so high).
I know that my temp monitoring software is off (when I start up my comp right away it reads about 7 C above ambient...). Do you guys think that being that is off by a lot the rest of the readings may be off by some too? I've used speedfan and ITE Smartguardian (came with mobo) and they give me the same readings. This is the origional driver from the mobo because I cant find the new one... If you could point me to something else to use that may help please feel free to! And if there's a way to take a hardware reading myself I would like to know how.
Also, do you think that the Zalman really does cool better than the stock fan? I've thought about this before, and if the stock is better, i really dont want to go the trouble of pulling everything out and putting the origional bracket on...
I just want this comp to last a long time and be stable (maybe get a few extra mhz out of the processor while i'm at it
). So if you have any other suggestions, please feel free to tell me!!!
CPU
My idle temps were: 44-45C now: 42-43C
My max temps were around: 55-58C now: 52-53C
System (has to be off...)
were:40C
now:38C
ambient is usually around 22C
All temps are after about a half hour or so, or after it's been warmed up with a game or something for at least 10 minutes (usually about an hour)
Thanks!!!
CPU
were:40C
now:38C
Thanks!!!
