I don't know that it would cost a fortune to change belts. I helped a buddy change a serpentine belt on his Prizm. He paid a little less than $30 for the belt and it didn't take us very long to replace it, only ten minutes or so. I am sure on some cars belts would be more expensive and more difficult to replace, but on the Prizm it was pretty easy to do.
I assumed the mention of belts (plural) meant they'd change more than just the serpentine belt. Although, today I appear to have been making a lot of poor assumptions. I do wonder if my car would be harder, because I have the V6 Altima, so it's probably more of a pain to work under the hood. I'm not too sure though... I don't fix it myself, because of my warranty.
wow, you're an idiot. do you know how many throttle i've seen killed by someone just 'spraying them out'?
do not give advice ever.
also examine that little metal shaft that holds your throttle plate and see where it goes, genius.
It doesn't matter anyway.
Mechanics don't use 'real time', they use 'book time'. They will look the job up in a book. It will give them an hour figure, and that's what they use to bill you.
Most of the time, the number has little to no basis in reality. If it takes 10 minutes, I can guarantee they'll charge you for an hour(ignoring the fact that most mechanics minimum billable time is an hour anyway).
Why would the belt running your AC and alternator care if the transmission is CVT?In a CVT, I'd definitely change it every 30k miles.
He's probably talking about the AT fluid.
Does a CVT really require changes every 30k? I could see 60k maybe, but 30k seems extreme...
