Would Wc3 frozen throne look any different on a better card than a radeon 7970?
Naer
3,482
182
would it?
I'm wondering if a game as old as this could take advantage of a higher end card. I have a i7 8gb setup btw
lupi
32,539
260
Given age of the game I think a "no" would be an easy statement to make.
railven
6,604
561
Go balls to the wall with forced SSAA and enjoy some weird ass artifacts haha. At least that was my experience the last time I tried playing WC3.
Which I think was on my HD 7970 2-3 years ago. Haha.
Ranulf
2,895
2,556
Eh, I remember it playing quite well on a GF3 Ti200 or a GF4 ti4400. I'd say a 7970 would be adequate. :)
el etro
1,584
14
Using VSR(AMD) ir DSR(NVIDIA) would help some. Is even better than force AA.
cyclohexane
2,837
19
Dude, this is like a 12 years old game. You don't need an i7, probably will run on an iPhone 4.
tential
7,348
642
121
No... You could use vsr if you want but then you soul get a 380 so you can vsr from 4k... And that's a decline in performance for you. The only improvements would be a 1-2% in iq for hundreds of dollars.
RussianSensation
19,458
765
would it?
32-40" 4K or especially 34" 3440x1440 monitor would offer a better gaming experience over a 22-27" 1080P/1200P or a 1440P monitor. Therefore the most logical step is to get a new monitor first and then if you feel that you need more GPU horsepower than a 7970, only then upgrade the GPU. IMO, for WC3 or SC2 style games, the best way to improve your gaming immersion is more pixels + larger screen size. These trump any GPU upgrade for this genre of gaming.
Source
Just make sure to check if WC3 supports 3440x1440 as it's a really old game. I think WC3 might actually not support 21:9.
railven
6,604
561
Also not sure if OP asked, but SC2 also does not support 21:9 support.
IllogicalGlory
934
346
Through registry edits (simple ones), Warcraft 3 can support any arbitrary resolution. Here are the results:
To answer the original question, you can crank catalyst settings (8x SSAA at 1440p) to the point where you become GPU limited in this game. I've done so, and ran into a GPU bottleneck with the rig in my signature, but I just put everything on maximum to see what happened. You could easily get that same IQ without cranking things so high and you wouldn't come anywhere near a GPU bottleneck. Playing custom maps, I routinely run into CPU bottlenecks though. :thumbsup:
alcoholbob
6,390
469
I believe the game is fixed to 4:3 resolution though. I remember back in 2001 getting a widescreen Dell monitor (2001WFP) and the game looked all wonky. Current Blizzard titles I believe are limited to 16:9. Other resolutions will just result in image stretching.
cen1
157
4
@IllogicalGlory: With all the forced enchantments you used, does the game actually look any better or is it just a waste of time more or less? I am asking because textures are really showing it's age so I have doubts whether any of this actually helps. If it's a yes, I'll do it this weekend on my 1440p and r9 390 :D
Naer
3,482
182
Sorry everyone, the card I have is not actually a 7970 but a amd Radeon 7570. "7570"
cen1
157
4
Card does not really matter. If you have everything on highest settings and get 60+fps that is the best you can get (without forced driver processing).
Naer
3,482
182
why do people buy new cards?
sm625
8,172
137
A 7570 maxes out WC3. I used to play that game with max settings on a 8600GTS, which this card beats in every way.
Naer
3,482
182
I own and plan on playing more starcraft 2. Would I get higher resolution with a better card for sc2?
Makaveli
5,000
1,589
With the most recent patch for SC2 killing some weaker computers now you may want to upgrade for better performance.
Naer
3,482
182
And the gpu is the key component to upgrade? Considering I have i7 8 gb. How many more resolution options will I get with like say a 4 gb gpu?
tenpole
265
I think my Voodoo 3000 used to struggle with the game when it got overcrowded.
