Would this power supply be enough.
b4bad
Hi everyone.
I have been using my system with this configuration for a while.
Power supply:
FSP Group AX500-PN ATX2.2 500W Power Supply
Rest:
Quad6600.
2Gb ram Corsair
320 IDE HDD
320 SATA HDD
200 SATA HDD
LiteON DVD DL
COOLER MASTER Centurion 5 CAC-T05-UB Black /Blue Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case... http://www.newegg.com/Product/...x?Item=N82E16811119047
ASUS P5K-V LGA 775 Intel G33 ATX Intel Motherboard .... http://www.newegg.com/Product/...x?Item=N82E16813131184
THe problem is...... i intend to add a good graphic card to this setup.... most likely... this one... http://www.newegg.com/Product/...x?Item=N82E16814130317 .......
you think the powersupply is good enough?
Reply awaited.
Take care
b4bad:brokenheart:
why would you get that Graphics card?
You can get an 512MB 8800GT that is $50 cheaper that is also faster.
Also the FSP AX500 is rated on Peak rather than Continuous wattage.
It is really a 450Watt PSU, not a 500 Watt. Also it has no Power Factor correction
You are probably ok...but I personally would replace that PSU.
well the graphic card you are talking about is for PCI express 2.0 ..... and my motherboard has PCI express 1.0 at 16X....... thats why i cant buy it........
take care
b4bad
take care
b4bad
PCI-E 2.0 is backwards and forwards compatible with PCI-E v1.x
Contact your motherboard manufacturer and I am sure you will find the G33 chipset will support a PCI-E 2.0 card just fine.
I would say spending the time to contact your motherboard manufacturer is worth it to save money and get better performance.
whoa..... whoa..... i dint know that...... i have been disconnected from the world of PCs for too long........ damn macs....... i need to do more research and not waste ppls time here....... however, thank you H00fan 1....
take care
b4bad
