TurtleCrusher
I've got a RAIDMAX HYBRID 2 RX-530SS 530W modular power supply. I've had this psu for 3 1/2 months now and used to OC my video card to insane clocks (665/910) and never had a problem.
After a lightning strike and a power surge happened near my house (i just moved in) my computer has been shutting off randomly while under load. My computer wasn't behind a surge protector as i just turned it on to see if the outlet worked :-/ Now whenever i run any CPU intensive programs the remote temp in speedfan (which i believe to be my PSU as my cpu temp is there and shows normal readings) can skyrocket to 105C in no time. I watched speedfan as i was playing dirt and it hit up to 130C before my computer turned off. Now when i have a nifty little desk fan down there on high the remote temp tops out at 80C; which is fine as it doesn't shut off.
Is it my PSU that is a problem? Or is that temp actually my CPU? I really doubt my cpu would go that high as my cpu still works wonderfully at this moment.
Also if it is the case of a bad psu, which one should i get? My componets are listed in my sig.
Here are some that i was looking at.
CORSAIR CMPSU-550VX 550W ATX12V V2.2 Power Supply $89.99
OCZ StealthXStream OCZ500SXS 500W $59.99
Antec BP550 Plus 550W ATX12V V2.2 Power Supply $59.99
OCZ StealthXStream OCZ600SXS 600W $79.99
Tuniq Potency PSU-POT550-BK 550W $85.99
