How do I find my maximum RAM FSB? I am trying to get this Opty over 3GHZ, at 2.85 GHZ now. Here are my settings.
FSB Bus Frequency............................. - 315
LDT/FSB Frequency Ratio....................... - 3x
CPU/FSB Frequency Ratio....................... - 9x
PCI eXpress Frequency......................... - 100Mhz
HT Buss speed ......................... - 945 MHZ
CPU VID StartUp Value......................... - 1.35v
CPU VID Control............................... - 1.40v
LDT Voltage Control........................... - Stock
Chip Set Voltage Control...................... - Stock
DRAM Voltage Control.......................... - 2.60v
DRAM Configuration Settings:
DRAM Frequency Set............................ - 150 (DRAM/FSB:3/04)
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3
RAS# to CAS# delay (Trcd)..................... - 4
Min RAS# active time (Tras)................... - 8
Row precharge time (Trp)...................... - 4
Row Cycle time (Trc).......................... - 12 Bus Clocks
Row refresh cyc time (Trfc)................... - Auto
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 02 Bus Clocks
Read to Write delay (Trwt).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 3120 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Off
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Normal
DRAM Data Drive Strength...................... - LEVEL 1
Max Async Latency............................. - 10 NS
DRAM Response Time............................ - Normal
Read Preamble Time............................ - 8.5 NS
IdleCycle Limit............................... - 256 Cycles
Dynamic Counter............................... - Disable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(8 Bursts)
