- Feb 8, 2001
- 8,968
- 16
- 81
I'm thinking of connecting my Xbox wirelessly to my router; unfortunately the wired-to-wireless ethernet bridges I've seen are pretty expensive. However, 802.11B access points that have RJ-45 jacks are pretty common and much cheaper.
I was wondering if it would be possible to use an 802.11B access point as a bridge for my xbox. It's not really practical to route a wire from my router to the xbox so I have to go wireless to play XBL. I'm hoping I can use the 802.11B AP to connect to my existing 802.11G network without causing a security hole.
Anyone have any experience doing this? If so, any recommended brands/models that would work well? The router I currently use is a D-Link 802.11G (I forget the exact model number).
Thanks in advance.
Thanks in advance.
