switch my Chieftec aluminium dragon casing (with the stamped metal grills removed and running 4 Panaflo L1A's at full speed) to an Antec SLK3700AMB (with 2x120mm fans, prolly panaflos). Would the airflow be about the same?
I have no idea what making the noise in my case. It actually got louder AFTER I removed the stamped grills! 😕 But that's also after changing from 8RDA+ (passive-cooled NB) to a Abit NF7-S (active cooled). I even took out the fan of my Radeon 9700pro's fan and gave it a thorough cleaning.
I might get rid of the NB fan on my motherboard and replace it with the gold-colored Zalman passive heatsinks but I'm concerned that it might not like 1.7v w/o active cooling.
It's not very loud, but still pretty annoying when the room's quiet. What else could be making the noise.. the vid card?
Help?
Edit: Other info - Antec Trupower 430, YStech 80mm adjustable on SLK800A. Overclocked. Actually everything else is in sig!
Help?
