Originally posted by: edplayer
Originally posted by: iFX
Brisbane is the better CPU. It's smaller, uses less power, produces less heat and will overclock better. Therefore, 65 nm Brisbane > 90 nm Windsor.
It uses less power.
Most threads that I have read say they overclock about the same. It has half the cache. It does LESS work, clock for clock. Also, his 4800+ uses a half multiplier so it won't even run the memory at 400MHz unless it is overclocked. The 6000+ does not use a half multiplier.
AND to top it all off, the Brisbane has longer L2 cache latency:
http://www.tomshardware.com/re...fight-back,1455-5.html
http://www.anandtech.com/cpuch...howdoc.aspx?i=2893&p=3
So you really have to be nuts to think the Brisbane is better than the Windsor. Yes, it uses less power and if that were your only criteria for "best" cpu, it would win. But it would be more appropriate to call it the more power efficient cpu or something similar rather than the better cpu.
Just because it is newer doesn't mean it is better.
You keep trying to tell us when it was made. Doesn't matter if it came out in 1983, it is better than the Brisbane.
