96Firebird
- Nov 8, 2010
- 5,714
- 316
- 126
The card might not be bad, but your case may have poor airflow and this is causing the heat problem.
Which thermaltake case?
I had an Antec P180, then changed to a $50 budget Raidmax Cobra case. Temps went down 2-4C across the board with the same fan configuration and amount of fans. Many of the cheaper budget cases offer better airflow and configurations than enthusiast cases of old.
How hot did the GPU get before shutdown? CPU?
