Would AMD be better off if they had not developed Bulldozer?
Steelski
700
BD scales worse than SB actually. Not a positive there...
I think I need to clarify, for clockspeed gains it scales better, Sandy bridge has a kind of dip when you reach what are abnormally high speeds, Bulldozer does not seem to suffer in this respect, its has a near liniar scaling with clocks, which would indicate the architecture has lots of room of clockspeeds if thermals can be kept in check for the future, in terms of per core scaling, no it does not scale as well as obviously it has shared core resources. But think of it this way, if IPC can be improved without increasing size much then the design could all of a sudden be very appealing. the equivalent of 8 thuban cores at 4+ GHZ stock vs 4 ivy bridge 4+ghz cores is something worth noting.
TakeNoPrisoners
2,599
There is no such thing as a "dip". Sure you need higher and higher voltages per clock when you get over a point but performance is unaffected.
Lepton87
2,544
9
He was talking about performance gain leveling off as you increase clock rate, so not really a dip. I haven't seen any benchmarks to confirm this behavior.
exar333
8,518
8
Pipe dream.
nyker96
5,630
better off I cannot say, but it's definitely a painful learning experience for amd i'm sure.
Remobz
2,564
37
AMD looked pretty bad this last round. But, I am sure they will bounce back.
As for me, I am buying Intel for my next pc.
Anarchist420
8,645
www.facebook.com
If they can reduce the cache latencies to 1/5 or less (and increase the clock speed of the L3 cache) of what they currently are, then it may not have been a bad design (although the high cache latency may be inherent to the design; I don't know)
The super high latency cache is probably the largest problem.
scannall
1,960
1,678
It's never a waste to try and innovate. Even if something doesn't work the way you wanted, hoped or expected you can learn from it. It's awesome when everything works right the first time, but still quite valuable when it doesn't.
Olikan
2,023
275
bulldozer front end is actually a worst\equal problem,
it can feed 4 interger ops, it would be ok, since one core have 4 ops.... but it is shared with 2 cores...it should actually feed 8 ops!!!
seriously, i still like the idea behing bulldozer...but amd screw it up badly
podspi
1,982
102
The idea is that one core is unlikely to to saturate the front-end, so tying it to two cores will increase average utilization.
Does anybody know if the front-end is the main bottleneck in BD? I have a hard time believing it, just because BD seems to be a dog even in ST performance...
sandorski
70,215
5,794
Only time will tell if it was a waste. I suspect that as they make changes to it, it will prove to be worth the $/Time/Effort.
Olikan
2,023
275
StrangerGuy
8,443
124
What, you think R&D money and time drops freely from the sky to justify that?
Intel already concluded a long time ago way before BD that a new uarch built on an entirely new process was a bad idea, nevermind the whole high-clock, low IPC approach was stupid (once again proven by Intel), it was a trainwreck right from the very beginning. More like AMD can't learn from history here.
VirtualLarry
56,542
10,167
I'm interested in future AMD CPUs, I think the overall design vision has a lot of promise, but the actual execution so far has been somewhat of a let-down for Bulldozer.
The biggest problem that I have with Bulldozer, is not the lack of IPC, or anything related to performance, per se, but rather, the high power-consumption. For 32nm, it's bizarre and inexcusable. This is almost like AMD's 65nm, that consumed as much power as their prior 90nm CPUs. It took a long time for them to improve the process as much as was needed.
I came to the stark realization of the power-consumption of AMD CPUs, when I tried to shoehorn my 95W 1045T X6 CPU into my HTPC, with only two 40mm exhaust fans (and the PSU).
I set the BIOS warning temp to 65C, and shutdown to 70C. Well, after running DC apps on all six cores, CoreTemp was telling me that the core temp was 52C, but then the BIOS started beeping, and then a few minutes later it shut down.
I disabled the warning and shutdown temp settings, and booted Win7 64-bit again. Running CoreTemp, the temps seemed to start at 50C, and slowly increase to 65C.
At those temps, the exhaust air coming out the back felt warm enough to pop popcorn with. So I shut down the DC apps, and I'm going to swap the 45W dual-core back in.
Olikan
2,023
275
bulldozer is not like pentium 4, it is designed to have hight clocks, for sure...but amd screw up and delivered far worse ipc than phenom. IMO they tried to have the same ipc....
amd tryed a trade of, slight less ipc for slight more clocks....not huge clock monster for deep low ipc, like p4
BD231
10,568
138
Depending on how quickly/well they can clean up the issues I would say the window for BD being a good value product will be short if Intel keeps up the same pace it has for the past few years. If AMD had put more focus into IPC improvements with a proven design like Intel does yes, they'd of been much better off without BD.
BD is just a weird arrangement of old tech on a process that doesn't do it any justice, very illogical move for AMD in the long run.
grimpr
1,095
7
I believe the design is and was ahead of its time, tuned for a highly multithreaded world, the future of Bulldozer lies on APUs, heterogeneous cores, since its the only way to make it out of Intels grasp.
Idontcare
21,110
59
Do you have any links or data that backs any of this up? I'm asking because I'd really like to read more about it.
IntelUser2000
8,686
3,786
That's purely due to diminishing returns. Same was said for Prescott, wait, practically all the Pentium 4's. I've quickly learned it was all BS, that the reason for great scaling was because the performance was down in the dumps in the first place.
Bulldozer scales better than Sandy Bridge in another thing, that's power consumption. That hinders clock speed opportunities for the former. :twisted:
ed29a
212
Now, remove your client (Desktop) glasses and put on your server glasses. Suddenly, Bulldozer isn't an illogical move at all. They sure missed the implementation on many fronts, but the idea is damn good. I think that in the long run it will pay off once the 32nm process matures and more PD tweaks come in. If AMD can rein in the power consumption issues and boost IPC a bit, BD/PD will be a decent CPU.
People who complain left and right about Bulldozer on desktop should realize that this is not a desktop CPU, it's a server CPU with a desktop after thought: Hey, this could run on desktop too!
Chiropteran
9,811
110
As bad as bulldozer is, it's not as bad as the initial Pentium 4. And later, with Northwood, the P4 was basically competitive with AMD's offerings, even if it was slightly inferior in some ways.
If AMD can improve bulldozer in it's first revision as much as Intel improved the Pentium 4, it will be a very strong CPU.
blckgrffn
9,287
3,427
www.teamjuchems.com
So, BD is essentially Northwood P4 and not the ones paired with RDRAM? :)
Add me to the list that wants BD but wants them to get it more power efficient. I want to run it 24/7 100% and compared to the 2600k (or similar) I can likely justify spending the price difference on power bills alone. Not to mention I can get buy with a quieter cooling solution...
piesquared
1,651
473
Depends who you ask. If you ask reviewers obsessed with canned benchmarks theoretical numbers over user experience, and others with an interest in intel doing well (or AMD failing), of course the results will be biased. But if you ask random individuals without the ability to bias, then the results would seem to fly in the face of those results. Take [H] blind reality check for example: http://www.hardocp.com/news/2012/01/23/amd_reality_check_challenge. Maybe reviewers should take a little time to actually focus on what matters to, you know, consumers.
That blind test reminds me of when AMD compared to the Zacate APU to intel's much more expensive solutions at IDF, and the APU wiped the floor with intel's attempt. intel had Anand run right over to 'correct' what obviously had to be a mistake! But it just wasn't to be and intel ended up looking worse. lol
