Would a person be able to run a longer distance if they ran on all four?
b0mbrman
29,470
I would say yes.
wtf. are you a retard? Last I recall, humans evolved into bipedal organisms. We wouldn't be able to run on all 4s even if we tried. Try flapping your arms and see if you could fly.
Just because humans evolved into bipedal organisms, it does not conclude that they cannot run on all fours. Humans didn't evolve into bipedal organisms because it allowed them to run faster. Freeing up two appendages allowed tool use and thus made those humans more successful.
And nice try on obscuring the issue with your last comment. Please show me where in human evolution where humans could fly. :roll:
once again, your comments only prove that you're a classic retard. Humans evolved into bipedal organisms long ago and this means that we no longer have the same characteristics of our prior forms. In other words, we can NOT run on all 4s...crawl around a little bit but not run.
Exactly. That's why humans no longer have an appendix, nor tonsils.
mugs
48,920
46
Well, our bodies aren't designed to run like that... so no.
If our bodies were designed to run on all fours... well, we wouldn't have any more stamina than before, but it would help alleviate the pain in your legs from impacting the ground since each leg would be supporting less weight.
iliopsoas
1,844
I would say yes.
who knows?! maybe we're in the process of getting rid of the appendix and tonsils in our evolution. Tonsils actually serve a purpose although it's redundant. Lots of lymphatics there, FYI.
her209
56,336
11
I would say yes.
Sorry, you're the only retard here. If you seriously think that people can't run around on all four then you need to end yourself now. I'd love to see evidence that people cannot run on all fours.
b0mbrman
29,470
I would say yes.
I imagine we are, but things take time.
You do understand the point, though, right? Just because we've since evolved away from some need does not mean the capability is gone...could just be dormant.
And while this thread has taken it to a bit of an extreme, comparing walking on all fours to flying is just silly
preslove
16,754
63
What, no scotch drinkers??????????? Come on people, give me your suggestions!!! Guide a lowly whiskey n00b through the mystical gaelic land of pete, bogs, and sea.
iliopsoas
1,844
If we've evolved away from something long enough, those features would no longer even be dormant but would be completely lost.
He didn't say "walk." The OP said "run a longer distance." Running on all 4s is vastly different from walking or crawling for a short distance. The biomechanics would screw up your spine. Compare the human spine to other organisms. We have 2 natural lordoses and 2 kyphoses. It was built for bipedal motion.
Goosemaster
48,775
Our body is designed to travel on two legs. It has evolved as such.
I would have to say that, based on my observations of animals, the length of their stride is far longer due to the fact that they can create a stride that is limited based on a combination of the length of their body and legs, while with humans, our stride is limited simply by the length of our legs. While the length of our legs is a function of our height since most of us are rather proportional, our height is not a benefit as with animals, and it even serves as a hidnerance since it creates a larger surface area that causes more drag.
I am totally ignoring differences in muscles mass and flexibility of course.
Preslove, mind comping me for a apir of Crown Royals?
SagaLore
24,036
21
If done from birth, the distance they would be able to run on all fours would be greater than the distance they would be able to run on two, but they would not be able to run farther than a human being raised normally running on two.
Evolution and such...maybe if you created an isolated society where everyone ran on all fours, then reproduced amongst yourselves, naturally selecting, for hundreds of generations, you'd do decently...but until then, no
At which point we wouldn't be human. We would be cats.
preslove
16,754
63
Canading whiskey? CANADIAN Whiskey???????? CANADIAN WHISKEY?????????!!!!!!!!!!
NO!!!!!!!!!!
:p
Goosemaster
48,775
NO!!!!!!!!!!
:p
why you cheap partriotic bastard:{D
preslove
16,754
63
NO!!!!!!!!!!
:p
Ah, did I hert de cute goosey woosey? Here, take this little itty guy...*hands goosemaster a B.C. spliff*
CKent
9,020
This thread is now about scotch. I bought some glenfiddich special reserve 12 year aged last night. It's pretty good.
:thumbsup:
jagec
24,442
Our appendix is useless, much like our abilities at 4-limb locomotion. We're better at 2.
4-limb running IS much faster, but we'll never be able to do it right. Just not built that way. We're pretty good at long-distance walking or running, though.
Pacfanweb
13,149
57
It's the same 2 lungs you're breathing through, regardless of how you propel yourself. Using all 4 limbs would probably just run you out of breath sooner.
slpaulson
4,407
11
I doubt losing an appendix and tonsils would give an advantage to a person so they are more likely to live and reproduce over somebody with an appendix and tonsils, so why would we lose them?
And no, a normal person would not be able to run farther on all four limbs. We just aren't designed to work that way. Only somebody who is deformed would find an advantage to moving on all fours.
bunnyfubbles
12,248
well, if we can use tools, then maybe. Some form of arm extensions (such as crutches, but perhaps not as crude) might help - however such a thing would also add weight (a draw back).
We're meant to walk on our legs, our arms are too short and our center of gravity would be way too out of whack to make 4 limb locomotion practical let alone any sort of advantage. The more comfortable positions have most of the body's weight destributed over your arms - which they're not meant to take - and any sort of work around (such as a leaping motion where you use your arms to stay up and your legs to spring you forwards) requires too much energy to be practical over long distances (and would also cause problems with potential stress on arms due to the sprint action impact)
newmachineoverlord
484
It appears we need to test this hypothesis. You need to do a marathon three times and time your results. Once on two feet, once on all fours, and once lying down on your side and rolling yourself. I'm betting that the fastest method on a downhill marathon would be rolling, while the fastest method on any other marathon would be running on two feet.
