Would a laptop monitor help me ?
MickLabib
11
Hi guys,
This is my first post to the forums and I'm glad to be here. I have a major problem that can ruin my life and my career. I work on a 19 inch Asus LCD monitor and it's giving me hard times, my eyes are strained almost all the time.
I'm thinking about getting an affordable laptop like DELL 1564 and the display says
type : High Definition (720p) WLED Display with TrueLifeTM
internal resolution : 1,366 x 768
Would that be better than my 19 Inch LCD? I just want be able to read ebooks with no problems to my eyes, I'm not going to watch movies on the laptop. I just want something that doesn't give me those bright colors that are driving me crazy D:
I really need an advice!!!
Mick
Dec 10, 2005
28,877
14,127
Why don't you just play with the monitor settings? Do you tend to work in the dark with the monitor on? Try adding some extra lighting to the room or turning down the brightness of the monitor.
MickLabib
11
I played with the monitor settings and still no use, the lighting in the room is perfect.
Dec 10, 2005
28,877
14,127
I don't know if a smaller monitor would really help you. You might find you're straining more to see stuff.
What about playing with the text size from within Windows?
MickLabib
11
my problem is with colors, the bright colors of the monitor is driving me nuts. I tried to play with it but it seems that I make colors look like bale :(
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
If you are just looking for something to read books on, why not get a Kindle?
akugami
6,210
2,552
The technologies used in the manufacture of LCD's for desktops and the panels for laptops are the same. If one is giving you problems then, assuming the LCD is working fine, other LCD panels will give you the same issues.
It seems that it is some sort of brightness/coloration issue which means it might be a visual problem you have. I'd talk to an eye doctor about the eye strain. I'd also look into getting an LCD anti-glare filter to see if that helps cut down the problem.
MickLabib
11
anti-glare filter, I didn't know that there is such a thing for LCD. I thought it's only for CRTs, thanks for help. I will look into it
mpilchfamily
3,559
They have them for LCDs as well. Many come with a polarized lens on them for privacy. Helps to soften up the brightness of the screen.
