would a crossover cable work for regular ethernet?
some newer switches have auto-sensing ports and will internally change the wire pattern to match either a standard or cross-over cable, most older switches/hubs can't do that
but most have an uplink port so just use that as EA says
Barring uplink-specific ports, or advanced ports that autosense the connection, hub-to-hub or computer-to-computer connections require a crossover, whereas computer-to-hub connections require a standard Cat5.
Originally posted by: SubZeroX
I mean just plugging it into a ethernet port, would it work?
Depends what's on the other side. If it's another computer, then yes. If it's a hub, then no. If it's a switch, then maybe.
umm...don't know what's on the other side. It's basically the school network. I guess I just gotta give it a shot.
I thought auto sencing meant that they could dectect and run 10Mbs and 100Mbs connections on the same switch?? not rearage the connectors inside?
