rh71
For the bench press on a universal machine, do you consider the weight of the bar + what the plates are marked ? Makes sense, just wanted to be sure. The first plate is marked 20 but they are 10lb increments so I was confused. I don't think those bars (between a U / V shape) are standard 45lbs either...
I can't seem to figure out what my total bench weight is...
