I'm going to be building a new system, most likely in an Antec SX1040 case, and am trying to work out proper airflow in my case. I would like to put on a side panel with a side fan hole, but this introduces some airflow problems. I don't really want the side fan blowing in because it would look ugly to put a dust filter there, but if I have it blowing out I'll have 4 fans blowing out (2 back + 1 side + 1 PS), and only 2 in (both filtered, reducing airflow). I've heard this will cause more dust problems as air will get sucked in from any cracks due to low air pressure inside the case.
So, is it a viable option to run 2 front + 2 back fans blowing into the case (filtered, reducing airflow), with the PS and side fans blowing out? Would this require that the out-blowing fans churn out more CFM, or is it okay to have a higher air pressure inside the case? I don't know much about this kind of airflow because I've never really built a system before, nor used on with this many fans.
