- Aug 14, 2008
- 8
- 0
- 0
Hi.
I'm trying to get a printer shared on a 2 pc network, both are XP, and they are connected to a Linksys Router.
I've never used workgroups before, so this might not even be the right setup to use, but that's what im guessing is the way to do this.
Both PCs are on the same subnet etc
How do I get them in a workgroup? Assuming this is what will make the printer attached to PC A that is enabled for sharing show up in a add printer > browse network search that is done on PC B.
thank you
thank you
