Hi...
I would like change my computer, but i need two monitors for my job. What is the best solution with this kit, two video card (GeForce4 MX440 64DDR, and a TNT2 32megs PCI, but the problem with this solution, it's the Asus A7N266-E don't have the option "Init Display First" for select my AGP card by default) and the second solution is a one AGP card with two DB15(like the matrox G400) but i don't know which video card.
Athlon XP 1800+
Asus A7N266-E
1 gig DDR
Sound Blaster Audigy Platinium EX
CD-Rom 52X LG
CD writer LG 32X10X40
HD 80gig 7200RPM UDMA 133
What do you think about this... if the first solution is the best i can change my Motherboard for a Epox(because Epox have the Init Display First option). If my default card is a TNT2 PCI, do you think the performance will slow down???
And i have a other question about the new HD IBM Deskstar 120GXP. Do you think this new product have the same problem than before version Deskstar???
Thanx to advance!!! =D
Athlon XP 1800+
Asus A7N266-E
1 gig DDR
CD-Rom 52X LG
