Work units didn't get updated...
Spoooon
11,563
203
I started running RC5 again yesterday after a period of doing SETI. But, they didn't update my stats page. Is it possible for my account to expire or something? Or is there something I need to do? I didn't really have too much time to read on their web page, so I thought a quick post here would give me some suggestions to pursue. I suppose I shouldn't really worry until tomorrow anyway. Thanks in advance. :)
Russ
No, accounts don't expire. Are you sure you entered your eMail address correctly? Did you get your first flush in before the rollover? It occurs at 5PM Pacific time.
Russ, NCNE
Spoooon
11,563
203
I'm pretty sure I did. I guess I'll just worry about it if nothing gets updated tonight.
RaySun2Be
16,565
Spooon,
Make sure you are doing RC5 and not OGR. You should have the following in your .INI file:
[misc]
project-priority=RC5,DES=0,CSC=0,OGR=0
plus double check the email you specified against the email DNET has for you.
Spoooon
11,563
203
I've got it all setup right. I made sure that I was doing RC5 etc. I've got my email setup correctly since it's been sending logs. So, hopefully my stuff will get updated tonight.
