Work laptop for systems engineer
Desin
72
I'm a sys eng and I spend most of my time with vCenter/20+ web page tabs/10 putty windows/outlook/excel/powerpoint open. I'll admit it, I've been out of the consumer hardware loop for quite some time now. I need a new laptop and have no idea what to get. I work for a SMB(~100 employees) and I can probably get away with 1K. I'd be willing to throw ~200 of my own cash at the problem..so 1200 max.
Right now I have have a i3 based Acer TimelineX with 3GB of RAM. It really starts to lag out at times. It is also impossible to use without an external monitor because of the 11"/crappy resolution screen. This sucks as I'm having to do more and more work from home in off peak hours and I'm tethered to my home office when I could be sitting on my comfy sofa with the wife.
I'd like something in the 15" range with 1680x1050 resolution. I'd also like at least 4 cores and 8GB of RAM so Vmware workstation doesn't kill my system with a VM running. 8 threads would rock.
I'd also like the video card to play starcraft2/diablo3 at the native resolution if we get to the 1200 range. Any suggestions? Thanks!
Any suggestions?
vbuggy
1,610
Something in the HP DV6t range might be your only bet, although it's hardly a work machine. You will likely be able to spec a quad-core with a 1080p screen and a discrete GPU for somewhere around your budget.
Sunburn74
5,076
2,635
HP pro book with cpu upgrade or workstation level HP envy are reasonable to look at
mshan
7,868
HP has the HP Pavilion dv7t Quad Edition Intel Core i7-2670QM Quad-Core Sandy Bridge 17.3" Notebook Computer for $899.99 Free Shipping after Coupon Code: NBPD7697 (Exp Soon). $1399.99 - $500 off code: NBPD7697 = $899.99 Free Shipping
6.72bs; 17.3" 1920x1080 LED; Intel Core i7-2670QM 2.2GHz Quad-Core Sandy Bridge; 8GB RAM; 750GB HDD; Blu-Ray reader; 802.11n; Windows 7 Home Premium; ATI Radeon HD6490 1GB; webcam; fingerprint; 6-cell battery; 2yr warranty
http://www.techbargains.com/news_displayItem.cfm/272206
15.4 HP quadcore: http://www.fatwallet.com/forums/hot-deals/1132314/
Sounds like you may need Windows 7 Pro, though?
vbuggy
1,610
Yeah, ^that sort of spec would seem to be it.
Problem is, it's pretty much a lowest-common-denominator consumer machine and you'll get a usage experience commensurate to that. Its true that millions of undemanding / don't know better users might be perfectly happy with it, but would that be what you really want on a machine you rely on and hit up heavily all day, every day?
I would personally steer you to a w-series Elitebook, but the prices-even-with-coupons will almost certainly not be in your budget.
Desin
72
Thanks for the recommendations. I should have the approval budget next week and go from there. I may make a runs to fry's/BB this weekend to check out the build quality on some different brands.
