WordPerfect Problem
FettsBabe
3,708
I know this should be posted in another forum (and it is), but I need a response asap as I have some seriously pending documents that must be generated immediately....Does someone in OT know the ends and outs of WP???
I have Wordperfect 9 on my computer and I'm trying to print a box (one like you check on an order form if you want to order something). Anyway, it won't print it. In fact, it prints everything but the freakin' box!!!I've loaded all the fonts, etc. but can't locate a problem. Can someone help?????????
shiner
17,112
I had a similar problem in WP 9, finally gave up and used Word XP and got the job done. I have upgraded to WP 10 since then and it seems to work fine. Wish I had an answer for you. Good luck!
