I'm scrambling to get this assignment done and would be really greatful if someone could take some time to try and solve these problems.
#1
A triangle has a base of (4-x)cm and a height of (2x+3)cm
a. what is the maximim area of the triangle to the nearest tenth
b. what value of x will produce that maximum area?
#2
If a bullet is fired vertically with an initial speed of 100m/s, its height h, is metres, after time t, in seconds, is given by h=100t-5t^2.
a. what maximum height will the bullet reach?
b. how long is it in the air (assuming it falls back to the ground?
Thank you very much
#1
#2
Thank you very much
