WOODEN Case - Athlon II inside - FINISHED
bxcounter
9
Sequel to previous project..
http://forums.anandtech.com/showthread.php?t=2054645&highlight=wooden+case
So here is another one, made for best mate...
MBO = ASROCK A785GMH/128M
CPU = Athlon II x 2 240 / OC to 3.4Ghz / temp 45c
Cooler = Stock + 2x120mm intake and exaust slim vents (Scythe) controlled with custom potentiometer
Memory = 2x2 GB ddr2 1066 Mushkin
HDD = WD Caviar Blue 320GB - with custom aluminium holder
Power Supply = LC POWER 420 W / silent all the way
GPU = Radeon 4670 Ultimate, 512mb DDR 3
OS = Windows 7 Home Premium
Complete system weight, around 7 kg (exotic wood).
.. oh, and of course both 10mm led eyes glow with HDD acitivity :sneaky:
http://i806.photobucket.com/albums/yy345/bxcounter/Photo-0030.jpg
http://i806.photobucket.com/albums/yy345/bxcounter/Photo-0003a.jpg
Fixed the pictures so u dont need to click them to view. However only 10 max allowed per post, so i missed 2, if you like you can select to two ud like omitted instead... but i picked 2 out of random.
CnC Mod. Aigomorla.
aigomorla
21,087
3,598
i love wooden cases...
Very nice and clean job.
I Fixed your pictures so u didnt need to click them.
Read the bottom notes, there was 2 i couldnt include, if u want them, you will need to remove 2 from your 12 picture post. :p
bxcounter
9
Thanks "aigomorla" for fixing pics.
As far as noise is concered, it is very,very silent, and i posted temps which are going around 45C (3.4ghz) and im pretty satisfied since stock cooler looks like a piece of s..t
Power supply (draws air from bottom of the case through air filter) and disk ar located in seperate compartment and that surely helped with heating etc...
