Wood floor repair
Sep 29, 2004
18,656
67
In short, I have some strips of my wood floor that needs patching/replacing.
In short, I need to know how to proberly remove the existing wood and second, how do I get hte new wood in? How do a handle nailing the patches in? Do I have to counter sink them since I think I have to nail them from the top side?
I can do the sanding/finish work. It's jsut that I lack knowledge to the part of removlal and insertion of the new pices. Oh, important question. If one piece to remove is 6 feet long, how do I CLEANLY cut out a 3' portion so only half of that piece comes out? There is a reason I need to do this.
Safeway
12,075
11
I did this exact thing this summer. I took a wood chisel and a hammer, and removed the wood I was going to replace. I then cut the pieces so they would tightly fit in, and stained them to match. It's really simple. They toenail the boards together, so you can do the same.
wedi42
2,843
use drill bit to make several holes in a row across board, then use chisel to finish the cut.
remove board, fill with wood putty and your done.
Sep 29, 2004
18,656
67
Awesome
Sep 29, 2004
18,656
67
har har har
UnklSnappy
626
Circular saw set to thickness of flooring. Make 2 cuts 1/4" in from edge on both sides of the board along it's length. Then diagonal cut across board joining the first 2 cuts. Pull out peices. Remove bottom of grooved side of replacement board. If you have a nice tight fit you can glue in the board and just use a couple nails to hold it down. I use a Fein saw when I don't want to take out a full board. Much easier than a chisel.
Ornery
17
Nobody even asked what kind of flooring it is. Is it this new "Pergo" crap, or 3/4" oak? Is it an old pine floor, or what? A picture's worth a THOUSAND words!
