Won't stay on for more than two seconds
Sleek
113
EpoX 8RDA3I (first motherboard)
EpoX 8RDA+ (second motherboard)
Athlon XP 3000+ 166fsb (first chip)
Athlon XP 2500+ 166fsb (second chip)
Allied 400w PSU (first PSU)
Enermax 400w PSU (second PSU)
Some 250w PSU (third PSU)
1 stick of OCZ 256mb PC3200 (first RAM)
1 stick of Kingmax 256mb PC2700 (second RAM)
Temporary low-power TNT2
Okay, here's my story:
The pump for my water cooling system was slowly dieing day after day, so I took off my water block and replaced the pump with the same kind of pump, just new. Then, before I put everything back together, I blew out my case with a vaccuum to get all the dust and dirt out of it. I put the waterblock back on the CPU and turned my PC on. (which, at the time, is using all of the 'first' parts). I go into the BIOS to check out the temperatures to make it's all cool.
But, the temperatures were getting mysteriously high (low 60's) when they used to be in the mid 40's. I exit the BIOS to go into Windows so I can shut down my computer properly, but the computer turns itself off before it can fully load Windows. I tighten the waterblock on a little more just to make sure it's all even and tight and I turn the computer back on. Again, still have high temperatures. I exit the BIOS, the computer shuts off. But this time when I press the power button, it doesn't stay on for more than 2 or so seconds.
I have everything unplugged except for the CPU, video card, and 1 stick of RAM. I have tried different CPU's, motherboards, powersupplies and RAM but it still will not stay on.
jackschmittusa
5,972
Do you set a shutdown temp in the bios? Does the mb receive a cpu fan signal now? 2 second shutdown often means it is not.
Sleek
113
Yep, I think it was because I had my watercooling fan plugged into my powersupply and not my motherboard. Weird that it would do that now and not before. Oh well, thanks guys!
