have a kk266, 1000@1333 axia C, 133fsb been runnin for 2 months.
power to devices, fans, drives, no post
clear cmos
still no post, help
infineon memory 133
runin 10 x 133
no beeps at all
got it let it sit over nite, cleared cmos, unpluged usb hub, shes up..
shut her down , reconnected usb hub shes up.
did hear a little sound from power supply when i put the plug back in,
I'll order a new power supply
thanks
Check your power supply. You did say that you heard something from your power supply. what did you hear?
Try this board plugged into the other case's power supply. Will rule out one or the other.
