Woah, A Diesel Rotary?
Howard
47,982
11
Right, because nothing good has every come from experimentation and further engineering. It's a good thing we let the piston engine die back in the early 1900s due to pathetic power. 1hp? What the fuck good is that?
Did we have any feasible alternatives at the time?
overst33r
5,761
12
How much more does an LSx engine weigh? Like 20, 30 lbs more?
More like 200lbs.
Renesis 270lbs
LS1 460lbs
13b-rew 400lbs (some sources say around 375lbs)
Specifically the LS1 and the Renesis in the RX8.
Now if you compare the ancient turbo 13b-rew, which is what you might have been doing, things get much more even due to all the extra plumbing. Even then an LSx weighs nearly 50-90lbs more.
If power/weight is concern it's a no brainer, however if balance/handling is vital, the rotary wins.
zoiks
11,787
I'm actually glad that Mazda takes it upon itself to work on the technology to make it better. There is potential otherwise they would've given up a long time ago. And sure it's not for everyone but people do buy the RX cars.
punjabiplaya
3,495
Well, they said they're working on the things that everyone criticizes the rotary for: high oil consumption, poor fuel economy, and lack of low end power. If they can improve the engine even mildly (at least more than slightly) in these areas, why wouldn't it be an amazing engine?
edit: unintended pun with a diesel and high oil consumption
angry hampster
4,232
www.lexaphoto.com
More like 200lbs.
Renesis 270lbs
LS1 460lbs
Yeah I believe I was considering the stats of the FD motor. The renesis is much lighter than I realized.
theeedude
35,787
6,197
They would have to double the torque and power while keeping same fuel consumption to catch up to piston engines.
PlasmaBomb
11,636
How could a diesel rotary do 10k given that the limitation for diesels is often how quickly the diesel burns...?
StageLeft
70,150
It would an amazing engine; it would be a piston engine.
Demon-Xanth
20,551
The size of rotary engines have always made me think that they'd be best in an MR2 like package rather than a long hood one.
