WMP 11 installation problem
TheCrackedJack
309
Alright, so I'm running Media Center with SP2 and I go to install WMP11 from Microsofts site and the installation just idles at 16 percent so I have to use task manager to end it. Then everything is screwed up because I can't reinstall 10 to get some WMV codecs that I'm now missing back. This sucks, at least I used system restore so I got back to my original settings, but why won't WMP 11 install for me? Any folks running into something similar?
corkyg
Elite Member | Peripherals
27,370
240
BSOM! I downloaded and installed WMP11 this afternoon, and it works beautifully - very impressive. It did take quite a while to finish the installation, however. Media Center must be different than XP Pro.
TheCrackedJack
309
How long did it take to install? I let it sit at 16 percent for at least 5 to 10 minutes, surely it coudn't take that long.
corkyg
27,370
240
All told, it was about 10-12 minutes. It went through and re-catalogued all my existing holdings abd playlists. The more you have, the longer it will take.
mzkhadir
9,509
does it download the full installation
TheCrackedJack
309
While it was at staying at 16 percent I checked the task manager, and the CPU was always at 0 so I don't beleive it could have been doing anything. What do you mean by does it download the full installation?
corkyg
27,370
240
OK - the jump to 33% is normal - and then it stays there for a l-o-o-n-g time and jumps to 56%. It is not there long and it jumps to 83%. It stays there a couple of minutes or so and then finishes. But - it's not done yet. Probably about 4 more minutes to get the rest of the stuff installed. I put it on two more machines this morning, and it behaved the same on all of them. Average - 12 to 15 minutes total.
TheRyuu
5,479
14
When I tried to install it I got some stupid WGA message saying my Windows Copy wasn't genuine. WTF?!?!????111
I hate this stupid wga. My windows copy is good, genuine copy! I paid MONEY for it. Well, there's a first time for everything. :(
TheRyuu
5,479
14
Originally posted by: DaY
WGA is still full of bugs. It said my copy wasn't legit once, but then it worked later.
Well, Like all other things WGA, after 1min. of googling I found away around it. Basically on one of the sites was some coding for a batch file that you can make that installs and excecutes the programs inside the WMP11 file manually (after you extract it) and it's the same thing.
