Wits' End (Power Supplies Don't Work)
Building a system around an AsRock H97M Pro4. Maybe this is a motherboard question.
I have tried four power supplies now.
One was a doorstop. (CX430.) Corsair also made the CX430M in my server, which is silent and never turns off, so they are automatically forgiven.
I've tried a "EVGA 430w 80 Plus" and an Antec Basiq VP450 as well (both purchased in the last week.) Both units test good on my little $2 PSU tester, and both units power up my other spare "parts" PC. But neither one will work with this motherboard.
Caveat - the EVGA unit worked once. One (1) time.
Finally, however, I have a 250w ITX-style PSU (Apevia ITX-AP250W) that powers the thing up fine - every time I press the blasted power button, without hesitation or failure. I had the rig running Prime95 all weekend, and I'm using it to post this. I'd just throw that in the rig and call it a weird day, but it won't fit, since it's a different form factor.
Is there some weird PSU requirement I'm completely ignorant of here, or do I just have the most selectively defective motherboard in the history of humankind?
Oh, and since somebody might ask - I've got all the parts out on a workbench so nothing is shorting against a case or anything. (Already thought that might be the problem.)
shocked the antec failed.
they are my go to 2u power supplies!
do you think it has something to do with haswell sleep states?
Sounds like motherboard. You could try rearranging the power cables differently or update/reset BIOS settings.
Or try one of these maybe (all Seasonic OEM)
Seasonic G-Series SSR-550RM $90
XFX Core Edition Pro P1-650S-NLB9 $92
Seasonic X-650 (SS-650KM3 Active PFC F3) $100
XFX Pro Series Black XPS-650W-3XB (P1-650X-XXB9) $99
Corsair HX650 $120
Creepier and creepier.
Upgraded the BIOS (which had some fixes for sleep states, so it said) and disabled C6/C7.
The Antec PSU worked! Excited, I assembled the machine, only to find that it didn't work anymore.
However, the computer has started turning itself on after a few minutes. It's intermittent, so I haven't figured out if it's a delayed reaction to the power button being pressed, or if it's just magic.
I'm going to stop at MC and get a new motherboard tomorrow.
Welp, I got a Gigabyte GA-H97M-D3H today.
SAME. PROBLEM.
It works with the dinky ITX PSU, but plugged into the others, it just won't power on.
WTH?
I am, however, pretty much convinced that there's something really stupidly simply I'm missing here...
Not trying to be a smart ass, but try a different motherboard.
Another different Haswell mobo?
They all work with my little Celeron box. (1037U on a Foxconn board.)
I guess I could build a c2d rig with what I have left in the closet. I'll try that tomorrow.
This is weird though, right?
I don't understand why your mobo is being so picky. It should at least post with the crappiest of power supplies. I would try a different model or brand of motherboard. Yes, Haswell. Make sure your power supply is Haswell ready. That's all I can think of.
Well... I feel like an idiot.
Turns out it was my workbench power strip/surge protector. I plugged it into another wall socket with the PSU that hadn't worked before, and it started up like a champ. (I turned it off and on like 10 times just to make sure.)
Turned off one of the other computers running on the workbench (they're usually 24/7 and I've never really thought about it since they pull <300w between them) and it powered right up.
So... yeah. Startup surge amperage or something must be a thing. I guess I have some PSUs to return to MicroCenter.
