- Aug 11, 2000
- 23,168
- 0
- 71
SLR has to do with viewing mechanism right?? with so many people using and leaning to the LCD for shooting Digital pics, what is the advantage of the SLR now??
Originally posted by: FeathersMcGraw
SLR is true WYSIWYG framing. Non-SLR cameras have parallax issues; that is, what you see in the viewfinder/display is slightly offset from the picture that actually gets taken. For point-and-shooters, this is not an issue. For people concerned about photo composition, there's no question about whether SLR is useful.
Originally posted by: GTaudiophile
Multiple lenses.
Canon's DSLRs use much nicer CMOS sensors (made by Canon). Canon's non-SLR CCD sensors are made by Sony I think.
Multiple lenses.
Multiple lenses.
I believe there are some digital SLR cameras with fixed (non-interchangeable) lenses. I don't know of any 35mm cameras where that's true, however.
Multiple lenses.
and 35 mm paradigm is meaningless when discussing digital cameras right?
Multiple lenses.
i always understood that slr was not synonymous with allowing multiple lenses. you can have lens mounts for non slr cameras right?? and fixed lens cameras can be slr's?
Multiple lenses.
There's no technical reason for SLR to imply interchangeable lenses, but generally SLRs have interchangable lenses.
Viewfinder cameras can theoretically have interchangeable lenses, but the built-in viewfinder will become useless. Although with a digital camera, since the LCD is a view through the lens, it can still work.
Multiple lenses.
so, interchangeable lens is not an advantage of the SLR technology.
i'm just asking about the SLR and how it is advantageous over the lcd viewfinders that are becoming so popular.
it would seem to me at some point SLR will have a much more limited role. particularly i see prosumers and sports photographers going for viewfinders that allow for various angles that are impossible with SLR's.
Multiple lenses.
Limited role? Tell that to all the people rushing out to buy Canon's digital rebel!
I have no idea what this means. What you shoot depends on your lens, not your viewfinder. SLR is simply a technology which allows you to see exactly what sort of image you are capturing when you press the shutter button.
Multiple lenses.
obviously the change will not happen overnight as paradigm changes are usually difficult.
i'm willing to bet there are more serious photographers using LCD viewfinders now than there were 3 yrs ago.![]()
Multiple lenses.
Originally posted by: Dead Parrot Sketch
The main reason for sports photogs using SLRs is the long fast lenses they need, you can't get those lenses any other way.
I doubt that they are manually focusing much of the time, they probably either pre-focus based on distance or use auto-focus if it's fast enough.
But that's just a guess.
Multiple lenses.
I'm willing to bet there aren't. Go to any major sporting event and see what the pros are using.
The trouble with using an LCD as a viewfinder is that you can't tell what's in focus. Not a problem if you're photographing little Tyffany and Zachary under the Xmas tree, a huge problem if you're photographing a halfback who's running full speed 100 feet away surrounded by other players.
i always thought that sports photographers just took as many pics as possible and just used the onese that looked good. machine gun approach vs sniper approach.
