I have a 90 watt power adapter from an older notebook that will work with my HP DV5-1015nr. I transport my notebook between home and office. I'd like to utilize the older power brick, so that I won't need to transport a power adapter back and forth. The tips on both adapters, of course, are of a different diameter. So I bought a plug for the older adapter.
My multi-tester identifies that the tip is hot for both adapters. The older power brick has two wires: core wire to center pin (19VDC +) and shield wire to outer cylindrical part of plug (0 VDC -). The newer power adapter has three wires: shield wire connected to the core tip (delivering 19 VDC +), white connected to inner part of cylindrical plug (also 19VDC +), and black wire connected to outer part of cylindrical plug that must be the ground (0 VDC).
Logically the hot shield and white wires on the new plug need to be connected to the hot wire on the older adapter. I just need someone who is 100% certain to confirm this, so I can feel comfortable proceeding.
