Wireless Zero Help - Turns itself off
KraftyOne
8
Alright...I know there is some smart person out there who can help me with this...
I'm working on a laptop that I just reformatted and installed a fresh copy of XP. I did all the updates too. When the computer boots up, it has no problem getting online wirelessly. However, after a while (always when it is not being used, so I'm not sure how long it takes) the wireless will disconnect. If I go to "View Wireless Networks" it tells me that the Wireless Zero utility is not running. Sure enough, if i go check out the Services, the Wireless Zero Service shows current status as "disabled" (startup is set to "automatic"). If I then enable Wireless Zero Services, I can go back and get a list of access points and it appears to connect. However, I still cannot get online.
The only way that I have found to get it to work again is to reboot the computer... then it works for a while... and quits.
We are using the internal NIC and this is an HP laptop.
Any ideas? Thanks!
bwatson283
1,062
make sure the startup type is set to Automatic, click the log on tab, make sure it is enabled at the bottom.
