Hi folks,
I'm setting up Xbox Live wirelessly at home, using that Xbox wireless adapter MS makes. I had tried a Linksys one before, but it didn't work well at all. My network is 802.11b, so I don't know if that might be slowing me down. Anyways, if you don't mind, can you run your connection speed test and tell me what you are getting? For those who don't know, I mean from the main screen, like what you see with no disc in the machine, pick Settings... Network Settings... Connect, and then run the four "tests" and put the cursor over Done and hit Y.
I'm looking for the numbers next to UL, DL, L, and P. Just want to compare with what I have to see if XBL should be working properly.
Thanks in advance 🙂
Thanks in advance 🙂
