Wireless woes
king4lex
Hi,
I've got a strange problem. I just bought a wireless card for my laptop. Its a Dlink Airplus (DWL-650+). I installed it correctly and when I first used it, it worked great. But the next time I tried it, it would not work. The Dlink utility says I am getting an awesome signal, although Window's Wireless Connection Status says the signal strength is "Very Low" to "Low" (it varies). I cannot ping any web site. I cannot even ping the router.
In the "Activity" box in the Wireless Connection Status window, it says several thousand bytes have been sent, but 0 received.
The active clients section in my router's control panel does not list the laptop's connection so I guess it is not connecting to the router. I have a Linksys WRT54G Wireless-G router. The connection from my other computer works fine, its just from the laptop that it does not work.
I have tried uninstalling and reinstalling the drivers on the laptop, but to no avail. Its really puzzeling especially since it worked perfectly when I first installed it. Any ideas?
