Wireless usb connection?
shabby
I need to hook up a printer to a pc through usb, but the printer is a couple rooms away.
Are there any wireless usb gadgets out there that can help?
You can get wireless print servers, they're little 802.11b box type thingies that you can plug the printer into. I dont know if they support USB, it may just be parallel. Linksys makes one, the thing is you'd need to have an 802.11b access point on your network.
