wireless usb 802.11b card with antenna jack?
exisle
1,282
Does anyone know of a USB to 802.11b\g adapters that have any kind of jack for an external antenna? I am looking for one to use for my home made antenna project.. if not I am also in need of a recommendation of a PCMCIA card adapter that has a jack... Thanks in advance
nweaver
6,813
most have the little tiny connections if you crack the case open, (same connection as a miniPCI card). Same goes with pcmcia. I know that the cisco CB21 had these if you peel the sticker off the end.
melthemoose
45
the old air-lmc352 does it, but I believe this is no longer made...but may still be available from stocking resellers
