I replaced my Mini PCI-E wireless LAN adapter, and it seemed to install the driver and recognize the card fine. Problem is it only has one antenna connector, whereas the original card had two. I didn't think that would be a problem and I just hooked up one of them, but when I turned on the wireless switch on the front of the laptop, the light doesn't turn on. The icon in the system tray says the wireless adapter has been disabled.
My questions:
Do both antenna connectors have to be plugged into the card?
Does the hard switch literally turn the card on/off, or just the antenna?
If it has to be on, is there any way to bypass it?
The company I purchased the card from said the card is only supposed to have one antenna connector (yet the product page shows two); is this a load of crap?
I'm using Windows XP Pro.
My questions:
