I built a PC for my mother for Christmas, and I made sure to include a wireless card since that's what her old computer needed. Her setup is downstairs while the Netgear wireless gateway (from Comcast) is upstairs.
Once in a while the connection will be lost, then redetected and connected again. While connected, the speed will be reported usually as 2MB/s or 5.5, though I have seen 11, 24 and 36 and as low as 1 (just before connection dies). Is this normal behavior?
I've never worked with wireless before. Is this normal? Is there something I can do to keep the connection live? Signal strength is either Very Good or Excellent. I set up this PC on my wired connection and simply used the driver from Windows Update (yes, I know people hate those drivers, but I usually have good luck with them). This PC also uses a cordless mouse, does that hurt anything?
