- Jan 9, 2010
- 4,282
- 2
- 76
Two buildings, left and right, with playground between and extending out. Wifi access is needed as far as corner of room 8 and wifi is going to be used for sending videos as well as email. Router is in room 3 and a hardline exists to room 2 where I have the "X" as proposed spot for wireless AP that will connect to hardline. If that's a desirable spot does it matter if AP is placed high (near cieling) or medium (on desk) for coverage spread? It will be close to a window.
No Ethernet runs exist to the building on the right.
Previously a wifi AP in the "X" spot didn't extend coverage well enough.
Any reccomendations for a good AP to put there. Is apple airport extreme a solution? Should I put a second one in room 6 or 7? and if so what's a good extender that will grab wifi and spit out a bubble with simple to use and adminster solution. Total network devices will be <50.
I need something that existing teachers can use and that won't require advanced tech skills, I'd like 1 wireless network name (2.4 and 5ghz band fine but I don't want more that 2 wireless SSID's for teachers to have to mess with). If things drop there will be no Tech on site, i'd like the drops either mitigated or easy to reset.
Will be very price concious for hardware, best case get solution done and setup for under $300. But a priority above cost is great coverage and simple to use and minimal wifi drops due to hardware.
