It's a hotel where they haven't actually finalized the Internet connection yet, but it's looking like multiple 25 meg lines coming in.
The main bottleneck will be getting Internet to the conference rooms and the nearby lobby. The meetings can have up to 20 people in a room. Ideally, there's going to be wired access also but I'm not in the industry and I don't know how feasible it is to tell 20 business people to all hook up to some type of switch using cat5 cables.
They're looking at wireless solutions, which is needed for the lobby anyway. So, what type of router/access point can handle this type of traffic? I'm assuming they might be doing some random VPN stuff and web browsing/email but hopefully no crazy torrents, etc. Semi-decent speed and good reliability are relatively important or else they'll just take their meetings elsewhere.
I was looking at some of the random Dlink stuff (like the DAP-2553/2590) but some reviews mentioned the frequent dropping of connections. The Cisco Aironet stuff is probably behind my ability to configure. HP seemed to have some offerings but I'm not sure if that's overkill or even which HP model to use.
Budget is slightly variable but cost has to be justified basically. So if a device that costs $100 can do it, great. If it needs to be $300, that's probably doable. $500 might be okay but really needs a good explanation about why it's necessary over cheaper alternatives.
The rest of the normal rooms and common areas can be slower so I was thinking just spacing out regular routers throughout the rest of the facility.
