MontysNotebook
I currently have an iPAQ Wireless Connection Point CP-2W. I was wondering if there's anyway to keep this connection point without having to spend a bajillion dollars to add some range to it. The signal is very weak when I go at a 45 degree angle downstairs. I'll mount something on my roof as needed, but remember to suggest the "lesser expensive" equipment. (I'm a teenager and it's hard to afford much at the moment. 🙂 )
If anyone could also tell me what is the best WLAN card (but again, inexpensive) I get that uses the 802.11b protocol would also be helpful. (2.4Ghz)
